Hazard Warning Switch: Description and Operation
DESCRIPTION
The hazard flasher switch is an integral part of the multi-function switch.
The hazard flasher system operates independently from the ignition switch. All turn signal lamps can be made to flash in unison by pressing and releasing the hazard flasher switch located on the top part of the steering column. The hazard flasher switch is identified by a "double triangle" symbol. The hazard flasher switch will move out or away from the steering column in the on position. The hazard flasher system is turned off by first pushing in the hazard flasher switch and then releasing the hazard flasher switch. The hazard flasher switch should remain in the depressed position which is the off position.
NOTE: The turn signal system is deactivated when the hazard flasher system is on. Turn signal and windshield wiper switch motion does not affect the hazard flasher system.
