Headlamp Dimmer Switch: Service and Repair
1. Remove the steering wheel.
2. Remove the four lower steering column shroud screws.
3. Separate the upper and lower steering column shrouds.
4. Remove the ignition switch lock cylinder illumination miniature bulb from the lower steering column shroud.
5. Remove the upper and lower steering column shrouds.
6. Remove the three multi-function switch screws.
7. Disconnect the multi-function switch electrical connectors.
8. Slide the multi-function switch off of the steering column.
