Flow of Diagnosis
1. Verify the customer concern by operating the headlamp system.
2. Visually inspect the components of the headlamp system:
Mechanical
- Improper headlamp cover adjustment.
- Damaged headlamp cover hinge.
Electrical
- Blown fuse(s):
+ 30 A HEAD.
+ 20 A RETRA.
- Damaged headlamp bulb(s).
- Damaged wiring harness.
4. Check for improperly installed accessories.
5. If fault is not visually evident, determine the symptom and proceed to the Symptom Chart. Symptom Chart (Without Autolamps)
