Flow of Diagnosis
1. Verify customer concern by operating the parking lamps.2. Visually inspect the components of the parking lamp system.
Mechanical
- Headlamp switch.
Electrical
- Blown fuse:
+ 15 A TAIL.
- Damaged miniature bulb(s):
+ Front side marker.
+ License.
+ Tail.
+ Parking.
- Damaged wiring harness.
4. Check for improperly installed accessories.
5. If fault is not visually evident, determine the symptom and proceed to the Symptom Chart. Symptom Related Diagnostic Procedures
