1. Verify customer concern by operating the illuminated entry system.
2. Visually inspect the components of the illuminated entry system.
Electrical
- Blown fuse(s):
+ 15 A METER.
+ 15 A R00M.
- Damaged bulb(s).
- Damaged wiring harness.
4. If fault is not visually evident, determine the symptom and proceed to the symptom chart. Symptom Related Diagnostic Procedures
