Flow of Diagnosis
1. Verify customer concern by operating the turn signal/hazard flasher system.
2. Visually inspect the components of the turn signal/hazard flasher system.
Mechanical
- Damaged turn signal switch.
- Damaged hazard flasher switch.
Electrical
- Blown fuse(s):
+ 15 A TURN.
+ 15 A HAZARD.
- Damaged turn signal miniature bulb(s).
- Damaged wiring harness.
