A-Z Component List
Component Location Connector* Denotes Information Not Available
4EAT Transaxle LH side of engine, on top front of transaxle C1012
A/C Clutch Cycling Pressure Switch RH rear of engine compartment, on A/C
accumulator C194
A/C Clutch Field Coil RH front of engine, part of A/C compressor
assembly C1013
A/C Clutch Thermal Protection Switch RH front of engine, on A/C compressor
assembly C1003
A/C High Pressure Cutout Switch RH front of engine compartment C128
A/C High Pressure Cutout/Fan Switch. RH front of engine compartment C128
A/C Relay LH side of engine compartment, in engine
compartment fuse box C132
A/C-Heater Control Assembly Center of Instrument Panel (I/P) C231, C287
Illumination Behind center of I/P C272
Anti-Lock Brake System Control Module Behind LH side of I/P, left of steering
column C222, C223
Anti-Lock Brake System Hydraulic Unit LH rear of engine compartment C173, C174
Anti-Lock Brake System Main Relay LH side of engine compartment, on RH
side of engine compartment fuse box C122
Air Bag Diagnostic Monitor Behind LH side of I/P, right of interior
fuse panel C209, C210
Ashtray Illumination Under center console, in ashtray C281
Backup Lamp Switch (2.0L Manual) LH side of engine, on lower front of
transaxle C162
Backup Lamp Switch (2.5L Manual) LH side of engine, on front of transaxle C162
Blower Assembly Behind RH side of I/P C265
Blower Motor Behind RH side of I/P, in blower assembly C296
Blower Motor Resistor Behind RH side of I/P, in blower assembly C297
Boost Sensor Rear of engine C1015
Brake Fluid Level Switch LH rear of engine compartment, on brake
fluid reservoir C124
Brake On/Off Switch Behind LH side of I/P, top of brake
pedal support C221
CD4E Transaxle Top of transaxle C146
Center Primary Crash Sensor Center front of vehicle, near engine
compartment hood latch assembly C156, C157
Central Processing Unit Behind LH side of I/P, on rear of interior
fuse panel C204,C213.
Cigar Lighter Center of center console, near ashtray C282, C283
Cigar Lighter Illumination Under center console, near cigar lighter C280
Clockspring Assembly Top of steering column, part of combination
switch C226, C257
Clutch Pedal Position Switch Behind LH side of I/P top of clutch
pedal support C230
Combination Switch Top of steering column C207, C225
Condenser Fan Motor Center front of vehicle, in front of
radiator C108
Crankshaft Position Sensor (2.0L) Top LH side of engine, part of distributor C129
Crankshaft Position Sensor (2.5L) RH front of engine C129
Data Link Connector C135 LH side of engine compartment, on fender
apron C135
Data Link Connector C190 LH side of engine compartment, on fender
apron C190
Data Link Connector C2090 LH side of I/P, near fuse panel C2090
Daytime Running Lamps Control
column C244
Distributor (2.0L) Top LH front of engine *
Distributor (2.5L) Top LH front of engine C134, C170
Dome/Map Lamp Assembly Center of windshield header C900
Driver's Air Bag Center of steering wheel C263
Daytime Running Lamps Relay LH side of engine compartment, in engine
compartment fuse box C101
EGR Check Solenoid Center rear of engine compartment C186
EGR Solenoid Valve (vacuum) (2.0L) RH rear of engine compartment C1007
EGR Solenoid Valve (vacuum) (2.5L) Center rear of engine compartment C1007
EGR Solenoid Valve (vent) (2.0L) RH rear of engine compartment C1006
EGR Solenoid Valve (vent) (2.5L) Center rear of engine compartment C1006
EGR Valve Position Sensor
(2.0L) LH rear of engine, on EGR valve C137
(2.5L) Center rear of engine C139
Engine Compartment Fuse Box LH side of engine compartment, above
wheel well
Engine Coolant Temperature Sensor On rear of engine C148
Electric Cooling Fan Motor Front of engine compartment, behind
radiator C118
Engine Oil Pressure Switch (2.0L) Lower RH rear of engine, near starter
assembly C1000
Engine Oil Pressure Switch (2.5L) Lower RH front of engine C1000
Evaporative Emissions Canister
Purge Valve (2.0L) RH rear of engine compartment C185
Evaporative Emission Canister
Purge Valve (2.5L) Center rear of engine compartment C185
Flasher Module Behind LH side of I/P, left of steering
column C243
Fog Lamp Relay LH side of engine compartment, in engine
compartment fuse box C1C2
Fog Lamp Switch Center of I/P C237
Fuel Pressure Regulator Control Valve
(2.0L) RH rear of engine compartment C187
(2.5L) LH front of engine C187
Front Heated Oxygen Sensor
# 11 Front of engine, in exhaust manifold C189
Fuel Injector # 1 Top of respective cylinders C181
Fuel Injector # 2 Top of respective cylinders C182
Fuel Injector # 3 Top of respective cylinders C183
Fuel Injector # 4 Top of respective cylinders C184
Fuel Pump Relay LH side of engine compartment, in engine
compartment fuse box C152
Fuel Pump Module Below rear of car, inside fuel tank C419
Headlamp Relay LH side of engine compartment, in engine
compartment fuse box C100
Headlamp Retractor Test Connector LH side of engine compartment, in engine
compartment fuse box C123
Heater Control Assembly Center of I/P C231, C287
High Mount Stop Lamp Top center front of liftgate, at top
of rear window C412
High Speed Blower Motor Relay Behind RH side of I/P, in blower assembly C298
High Speed Condenser Fan Relay LH side of engine compartment, on RH
side of engine compartment fuse box C164
High Speed Cooling Fan Relay LH rear of engine compartment C144
Horn Relay LH side of engine compartment, in engine
compartment fuse box C105
Horn Switches In center of steering wheel C263
Idle Air Control Solenoid
Valve (2.0L) Center rear of engine compartment, on
throttle body C188
Valve (2.5L) Top LH rear of engine, on throttle body C188
Ignition Coil LH front of engine compartment, near
engine compartment fuse box C171
Ignition Key Cylinder Lamp Top of steering column, near ignition
switch C225
Ignition Key Reminder Switch Top of steering column, part of ignition
switch C219
Ignition Switch Top of steering column C218
Inertia Fuel Shutoff Switch Lower LH side of luggage compartment,
behind wheel well C426
Instrument Cluster Top LH side of I/P C240, C241
Instrumentation Engine Coolant
Temperature Sensor Top LH side of engine C195
Instrument Panel Dimming Module LH side of I/P, left of steering column C235
Intake Air Temperature Sensor Top LH side of engine compartment, on
LH side of air cleaner assembly C192
Integral Generator Regulator RH of engine, on AIR C153
Interior Fuse Panel Behind LH side of I/P, near kick panel C201
C214, C215
C216, C217
Joint Connector C103 LH front of vehicle, near left fog lamp,
on G103 C103
Joint Connector C106 LH side of engine, on G106 C106
Joint Connector C169 LH side of engine compartment, in engine
compartment fuse box C169
Joint Connector C203 Behind LH side of I/P, on G203 C203
Joint Connector C234 Behind LH side of I/P, taped to I/P
harness C234
Joint Connector C262 Behind top LH side of I/P, taped to
air bag harness C262
Joint Connector C264 Below center front of console, near
Powertrain Control Module (PCM) C264
Joint Connector C269 Behind LH side of I/P, taped to I/P
harness C269
Joint Connector C270 Behind LH side of I/P, taped to I/P
harness C270
Joint Connector C300 Below LH front seat, on G300 C300
Knock Sensor Rear of engine C138
Left Primary Crash Sensor LH front of vehicle, behind front bumper C154, C155
Left Door Courtesy Lamp Switch On LH "B" pillar, in rear of LH door
jamb C306
Left Door Key Cylinder Switch In top rear of LH door, part of key
cylinder C501
Left Door Lock Motor In rear of LH door C505
Left Door Lock Switch In top rear of LH door, part of key
cylinder C505
Left Fog Lamp Left lower front of vehicle C119
Left Front Anti-Lock Brake System
Wheel Speed Sensor On LH front wheel assembly C1001
Left Front Combination Lamp LH front of vehicle C115
Left Front Door Speaker In lower front of LH door C504
Left Fuel Injectors Top of respective LH cylinders (front) C1010
Left Headlamp LH front of vehicle C117
Left Headlamp Retractor LH front of engine compartment C116
Left Front Heated
Oxygen Sensor # 22 Lower front of engine C1020
Left Rear Heated
Oxygen Sensor # 21 Lower center front of engine, near exhaust
manifold C127
Left Horn Inside front of LH front fender C178
Left Rear Combination Lamp LH rear of vehicle C401
Left Outside Door Handle Switch In top rear of LH door, near handle
assembly C500
Left Power Window Motor In lower rear of LH door C506
Left Power Mirror Top front of LH door C503
Left Rear Anti-Lock Brake System
Wheel Speed Sensor On LH rear wheel assembly C427
Left Rear Speaker In front of LH quarter panel, behind
quarter trim C429
Left Vanity Mirror Lamp On driver's visor C901
Left License Plate Lamp Center rear of liftgate, on respective
sides of license plate C415
Liftgate Key Switch In RH rear of luggage compartment
Liftgate Washer Motor Lower LH rear of luggage compartment,
on liftgate washer fluid reservoir C420
Liftgate Washer Switch Center of I/P C232
Liftgate Wiper Motor Inside LH rear of liftgate C416
Liftgate Wiper Switch Center of I/P C236
Low Speed Blower Motor Relay LH rear of engine compartment C145
Low Speed Condenser Fan Relay LH side of engine compartment, on RH
side of engine compartment fuse box C163
Low Speed Cooling Fan Relay LH front of vehicle, on front of upper
radiator support C167
Luggage Compartment Lamp LH side of luggage compartment C422, C423
Luggage Compartment Lamp Switch Center rear of luggage compartment,
near hinge support C405
Mass Air Flow Sensor Top LH rear of engine compartment, on
rear of air cleaner assembly C199
Master Window/Door Lock Control
Switch On armrest of LH door C502
Moon roof Motor Assembly Center of roof, behind moonroof C907
Moon roof Relay Center of roof, behind moonroof C906
Moon roof Switch Center of windshield header C900, 905
Park Brake Switch Below rear of center console, on park
brake assembly C308
Park Lamp Relay LH side of engine compartment, in engine
compartment fuse box C141
Park Range Switch Below center console, on front of gear
selector assembly C299
Park/Neutral Position Switch
(2.0L Manual) LH side of engine, on top of transaxle C198
(2.5L Manual) Lower rear of transaxil C198
Passenger's Air Bag Top RH side of I/P C274
Powertrain Control Module Power Relay LH side of engine compartment, in engine
compartment fuse box C104
Power Door Lock Relay Top of RH kick panel C290
Power Lumbar/Bolster Compressor
Motor Under center rear of LH front seat C305
Power Lumbar/Bolster Switch LH side of LH front seat C305
Power Mirror Switch On armrest of LH door C507
Power Seat Lift Motor Under center front of LH front seat C311
Power Seat Slide Motor Under center front of LH front seat C312
Power Seat Switch LH side of LH front seat C301
Power Seat Tilt Motor Under center of LH front seat C310
Power Steering Pressure Switch RH front of engine compartment, on power
steering line C196
(2.0L) Below center front of center console C256
(2.5L) Below center front of center console C245, C246, C247
C248
Pulse Signal Generator Lower rear of transaxle C131
Radio (AM/FM Stereo) Center of I/P C211, C212
C291
Radio amplifier In front of RH quarter panel, behind
quarter trim C314, C315
C316
Radio Noise Capacitor LH front of engine compartment, near
ignition coil C148
Radio/Compact Disc Player Center of I/P C211, C291
Rear Heated Oxygen Sensor # 12 Front of engine, in exhaust manifold C1031
Rear Window Defrost Grid On rear window C413, C417
Rear Window Defrost Relay LH rear of luggage compartment C418
Rear Window Defrost Switch Center of I/P C238
Remote Entry Module In front of RH quarter panel, behind
quarter trim C407, C425
Remote Entry Program
Connector In RH rear of luggage compartment C424
Right Primary Crash Sensor RH front of vehicle, behind front bumper C158, C159
Right Door Courtesy Lamp Switch On RH "B" pillar, in rear of RH door
jamb C307
Right Door Key Cylinder Switch In top rear of RH door, part of key
cylinder C601
Right Door Lock Motor In rear of RH door C605
Right Door Lock Switch In top rear of RH door, part of key
cylinder C605
Right Fog Lamp RH lower front of vehicle C120
Right Front Anti-Lock Brake System
Wheel Speed Sensor On RH front wheel assembly C1002
Right Front Combination Lamp RH front of vehicle C111
Right Front Door Speaker In lower front of RH door C604
Right Fuel Injectors Top of respective RH cylinders (rear) C1011
Right Headlamp RH front of vehicle C113
Right Headlamp Retractor RH front of engine compartment C112
Right Rear Heated Oxygen
Sensor # 11 Lower center rear of engine, in exhaust
manifold C130
Right Horn Inside front of LH front fender C179
Right License Plate Lamp Center rear of liftgate, on respective
sides of license plate C414
Right Outside Door Handle Switch In top rear of RH door, near handle
assembly C600
Right Power Window Motor In lower rear of RH door C606
Right Power Top front of RH door C603
Right Rear Anti-Lock Brake System
Wheel Speed Sensor On RH rear wheel assembly C428
Right Rear Combination Lamp RH rear of vehicle C402
Right Rear Speaker In front of RH rear quarter panel, behind
quarter trim C430
Right Front Heated Oxygen Sensor
# 12 Lower rear of engine C1030
Right Vanity Mirror Lamp On passenger's visor C902
Right Window/Door Lock Control
Switch On armrest of RH door C602
Safing Sensor Behind center of I/P C260, C261
Seat Belt Buckle Switch In driver's seat belt buckle assembly C304
Shift Lock Actuator Below front of center console, near
rear of gear selector assembly C220
Speed Control Module
(2.0L Automatic) LH rear of engine compartment, near
LH shock tower C110
Speed Control Module (2.0L Manual
& 2.5L) Behind I/P, left of steering column C227, C228
Speed Control Servo LH rear of engine compartment C175
Speed Control Switch Assembly On steering wheel C286
SPOUT Test Connector LH side of engine compartment, near
data link connectors C135 and C191, C177
Starter Clutch Pedal Position (SCPP)
Switch Behind LH side of I/P, top of clutch
pedal support C293
Starter Motor/Solenoid (2.0L) Lower rear of engine C176
Starter Motor/Solenoid (2.5L
Automatic) LH rear of engine C176
Manual) Lower LH front of engine C176
Subwoofer Amplifier In front of LH quarter panel, behind
quarter trim C317
C318
Subwoofer Assembly RH rear of luggage compartment
Throttle Position Sensor Top LH rear of engine, on throttle body C136
Transaxle Control Module Below center of I/P, forward of powertrain
control module C258, C259
Transmission Control Switch Front of center console C242
Transmission Range Sensor
(2.0L Automatic) Top front of transaxle C161
(2.5LAutomatic) Top front of transaxle C168
Turbine Shaft Speed Sensor Lower LH side of engine compartment,
on LH side of transaxle C131
Vehicle Speed Sensor Lower rear of transaxle C197
Volume Air Flow Sensor Top LH side of engine compartment, on
air cleaner assembly C150
Variable Resonance Inducation System
Solenoid Valve # 1 Center rear of engine compartment C1008
Solenoid Valve # 2 Center rear of engine compartment C1009
Washer Fluid Level Switch RH front of engine compartment, in windshield
washer fluid reservoir C133
Windshield Washer Motor RH front of engine compartment, in windshield
washer fluid reservoir C109
Windshield Wiper Motor Top LH side of safety wall C165
