Clutch Pedal Position Switch
Clutch Pedal Assembly:
The Clutch Pedal Position (CPP) switch signals the Powertrain Control Module (PCM) when the clutch pedal has been depressed. The PCM uses this information to determine if the engine is under load or coasting. It will also disengage the speed control system (if equipped).
