Starter Clutch Pedal Position Switch (SCPP)
The Starter Clutch Pedal Position (SCPP) switch signals the Powertrain Control Module (PCM) when the clutch pedal is depressed.
The CPP switch is closed when the clutch pedal is depressed and open when the clutch pedal is at rest, to enable and disable the starter solenoid.
