Removal and Replacement
Powertrain Control Module:
2. Remove the console panel access panel, located in front of the gearshift lever and housing.
3. Disconnect the electrical connectors from the Powertrain Control Module (PCM).
4. Remove the two PCM bolts.
5. Remove the PCM from the console panel.
6. To install, reverse the removal procedure.
