Idle Speed/Throttle Actuator - Electronic: Service and Repair
REMOVAL and INSTALLATION
1. Remove the throttle body assembly.
2. Remove the electrical connector and the vacuum hoses from the Idle Air Control Bypass Air (IAC BPA) valve.
3. Remove the four IAC BPA valve bolts from the IAC BPA valve.
4. Remove the IAC BPA valve and IAC BPA valve gasket.
- Discard the gasket.
5. To install, reverse the removal procedure.
- Replace the IAC BPA valve gasket.
- Tighten the IAC BPA valve bolts to 3-4 N-m (26-35 Lb-in).
