Power Steering Pressure Switch: Service and Repair
NOTE: It is necessary to remove the power steering pump to service the Power Steering Pressure (PSP) switch.
1. Disconnect the PSP switch electrical connector.
2. Remove the PSP switch.
1. Install the switch with a new O-ring and lubricate it with Power Steering Fluid.
- Tighten to 17-23 Nm (12-17 lb ft).
2. Connect the switch electrical connector.
