Required Equipment
REQUIRED EQUIPMENT (OR EQUIVALENT)
- Rotunda New Generation STAR (NGS) Tester 007-00500.
- Rotunda Vacuum/Pressure Tester 164-R0253.
-- Range 101.3 kPa (0-30 in Hg.)
-- Resolution 3.4 kPa [1 in Hg.)
- Rotunda Inductive Dwell-Tach-Volts Ohms Tester 164-R0254.
-- Range 0-6000 rpm.
-- Accuracy ±40 rpm.
-- Resolution 20 rpm.
Breakout Box:
- Rotunda EEC-IV 60-Pin Breakout Box 014-00322.
104 Pin Breakout Box:
- Rotunda EEC-V 104-Pin Breakout Box 014-00950.
Vacuum Pump:
- Rotunda Vacuum Tester 014-R1054.
-- Range 101.3 kPa (0-30 in-Hg.)
Digital Volt-Ohmmeter (DVOM):
- Rotunda 73 Digital Multimeter 105-R0051.
-- Input impedance 10 Megaohm minimum.
- Rotunda Evaporative Emission System Tester 134-00056.
