Vehicle Speed Sensor: Description and Operation
DESCRIPTION
The Vehicle Speed Sensor (VSS) generates an A/C signal which is sent to to the instrument cluster. The A/C signal is converted to a D/C signal and then sent to the Powertrain Control Module (PCM) to control such parameters as fuel injection, ignition timing, transaxle shift scheduling, torque converter clutch scheduling
