EGR Boost Control Solenoid: Service and Repair
1. Disconnect the five EGR boost check solenoid and fuel pressure regulator control solenoid valve vacuum lines and the EGR boost check solenoid and fuel pressure regulator control solenoid valve electrical connectors.
2. Remove the EGR boost check solenoid/fuel pressure regulator control solenoid valve bracket nut.
3. Remove the EGR boost check solenoid and fuel pressure regulator solenoid valve assembly..
4. Separate the EGR boost check solenoid from the bracket.
- To install, reverse the removal procedure.
- Tighten the EGR boost check solenoid / fuel pressure regulator control solenoid valve bracket nut.
