Fuel Pressure Test Port: Service and Repair
REMOVAL and INSTALLATION
WARNING: Fuel in the fuel system remains under high pressure even when the engine is not running.
1. Perform the fuel pressure release procedure.
Intake Manifold:
3. Remove fuel pressure relief valve.
4. To install, reverse the removal procedure.
- Tighten the fuel pressure relief valve to 8.5-9.5 Nm (76-84 lb in).
