Variable Induction Check Valve: Description and Operation
Check Valve:
The one-way check valve is used to prevent the Variable Resonance Induction System (VRIS) shutter valves from becoming inoperative during heavy load applications.
The check valve keeps the supply from the vacuum reservoirs constant for proper operation. The check valve allows flow in one direction but will not permit passage in the opposite direction.
