Variable Induction Check Valve: Service and Repair
REMOVAL and INSTALLATION
1. Remove the intake manifold.
2. Label and identify the Variable Resonance Induction System (VRIS) check valve vacuum hoses, then disconnect the vacuum hoses from the check valve.
3. Remove the VRIS check valve from the intake manifold.
4. To install, reverse the removal procedure.
