Variable Induction Control Solenoid: Service and Repair
REMOVAL and INSTALLATION1. Disconnect the battery ground cable.
Solenoids:
2. Disconnect the Variable Resonance Induction System (VRIS) solenoid electrical connectors.
Solenoids:
3. Remove the two VRIS solenoid bracket bolts.
4. Disconnect the VRIS solenoids from the VRIS solenoid bracket.
5. Identify and label the VRIS solenoid vacuum hoses, then disconnect the vacuum hoses from the VRIS solenoids.
6. Remove the VRIS solenoids from the vehicle.
7. To install, reverse the removal procedure.
