Power Steering Fluid Reservoir: Service and Repair
1. Disconnect the power steering fluid cooler and the power steering reservoir pump hose from the power steering pump reservoir.
2. Drain the fluid from the power steering pump reservoir.
3. Remove the two power steering pump reservoir bolts. Remove the power steering pump reservoir.
1. Position the power steering pump reservoir and install the two power steering pump reservoir bolts. Tighten the power steering pump reservoir bolts securely.
2. Connect the power steering oil cooler tube and the power steering reservoir pump hose to the power steering pump reservoir.
3. Fill the power steering pump reservoir with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33F. Follow proper power steering fluid capacity and filling procedure.
