Power Steering
1. Check for an overfilled power steering pump reservoir. Siphon off the excess fluid if necessary.
2. Check for power steering pump overflow or aeration.
3. Wipe the suspected area dry and check for the exact source of the leak. Oil may be running down from another area (other than the power steering system) and causing an oil drip.
CAUTION: Do not hold the steering wheel against a stop for more than fifteen seconds at a time.
4. Some leaks are high-pressure leaks and may require holding the steering wheel, for no more than fifteen seconds, against the stop to permit oil to seep out. Cycle the steering wheel from stop to stop ten times to check for leaks. The rubber boots may have to be moved back from the steering gear housing to see the leak.
