Band Apply Servo: Service and Repair
1. Remove the main control valve body.
2. Use a C-clamp and socket to compress the 2-4 servo. Remove the servo piston retaining snap ring, servo band piston and servo piston spring.
1. Position the servo band piston and servo piston spring in the case.
3. Install the servo piston retaining snap ring.
4. Remove the C-clamp and socket.
5. Install the main control valve body.
