Clutch, A/T
CAUTION: The composition clutch plates, valve body gaskets, bands, and synthetic seals should not be cleaned in a vapor degreaser, or with any type of detergent solution. To clean these parts wipe them off with a lint-free cloth. New clutch plates or bands should be soaked in the specified automatic transmission fluid (ATF) for two hours before being assembled.
Clean the metal components with a suitable solvent and use compressed air to dry all parts and clean fluid passages.
