Shift Pattern
DESCRIPTIONUnder certain conditions the Transaxle will downshift automatically to a lower gear range (without moving the gearshift lever). There are three categories of automatic downshifts: coast down, torque demand, and forced or kick down shifts.
COASTDOWN
The coast down downshift occurs as the name indicates, when the vehicle is coasting down to a stop.
TORQUE DEMAND
The torque demand downshift occurs (automatically) during part throttle acceleration when the demand for torque is greater than the engine can provide at that gear ratio. The Transaxle will disengage the torque converter clutch to provide added acceleration, if applied.
KICK DOWN
For maximum acceleration, the driver can force a downshift by pressing the accelerator pedal to the floor. A forced downshift into second gear is possible below 88 km/h (55 mph). Below approximately 40 km/h (25 mph) a forced kick down to first gear will occur. For all shift speeds, specifications are subject to variation due to tire size and engine calibration requirements.
