Fluid Line/Hose: Service and Repair
REMOVAL1. Remove the cooler hoses from the cooler tubes. Discard the spring type hose clamps and plug the cooler hoses.
2. Remove the cooler tube banjo bolts.
3. Remove the cooler tube clamp bolts.
4. Remove the cooler tubes.
To install, reverse the removal procedure noting the following:
^ Install the cooler hoses using new spring type clamps.
^ Check the fluid level and adjust as necessary
