Fluid Line/Hose: Testing and Inspection
^ When fluid leakage is found at the transmission fluid cooler, the transmission fluid cooler must be replaced.
Upon inspection, any cooler tubes or hoses that are defective or damaged must be replaced.
^ When one or more of the fluid cooler tubes must be replaced, each replacement fluid cooler tube must be fabricated from the same size steel tubing as the original fluid cooler tube.
^ Using the old fluid cooler tube as a guide, bend the new fluid cooler tube as required. Add the necessary fittings and install the fluid cooler tube.
^ After the fittings have been tightened, add fluid as needed and check for fluid leaks.
