Timing Solenoid, A/T
DESCRIPTIONThe shift solenoid (SS) assembly consists of seven individual solenoids. These are:
^ 1-2 Shift Solenoid:
^ 2-3 Shift Solenoid:
^ 3-4 Shift Solenoid:
^ Torque Converter Clutch Control (TCCC) Solenoid
^ 3-2 Timing Solenoid
^ Line Pressure Solenoid
^ Torque Converter Clutch (TCC) Solenoid
3-2 TIMING SOLENOID:
^ The 3-2 timing solenoid is located on the valve body and is switched on and off by electrical signals from the PCM.
^ The 3-2 timing solenoid controls the line pressure applied to the 3-2 timing valve.
