Stator Shaft: Service and Repair
DISASSEMBLY
1. Remove the bearing outer race with a pin punch.
2. Remove the front oil pump seal.
ASSEMBLY
1. Install a new front oil pump seal.
2. Remove any remaining locking compound from the bolt holes.
3. Use Pinion Bearing Cup Replace T80T-4000-E to press the bearing outer race into the torque converter stator support.
