Fluid - M/T: Service and Repair
DRAIN1. Raise and support the vehicle.
2. Remove the transaxle drain-plug and allow the transmission fluid to drain into a suitable container.
3. Install the transaxle drain-plug using a new copper washer. Tighten the transaxle drain-plug to 40-58 Nm (29-43 ft. lbs.).
4. Lower the vehicle.
FILL
1. Place the vehicle on a level surface.
2. Clean the transaxle case near the transmission fluid level plug to prevent transmission fluid contamination.
3. Remove the transmission fluid level plug and copper washer.
4. Add the correct amount of the specified transmission fluid to the transaxle, until the fluid level reaches the lower edge of the transmission fluid level plug port.
5. Replace the transmission fluid level plug using a new copper washer. Tighten the transmission fluid level-plug to 40-58 Nm (29-43 ft. lbs.).
