Reverse Idler Gear: Testing and Inspection
Check the reverse idler gear for:^ Worn or damaged bushing, gear teeth, or release lever coupling groove.
^ Excessive clearance between the synchronizer sleeve and the reverse lever.
Maximum allowable clearance is 0.85 mm (0.033 inch).
