Seals and Gaskets: Service and Repair
1. Remove the front wheel driveshaft and joint.
2. Use Impact Slide Hammer T50T-100-A and Bearing Cup Puller T77F-1102-A to remove the differential oil seal(s).
1. Use Differential Seal Replacer T87C-77000-H to install the differential oil seal(s).
2. Install the front wheel driveshaft and joint.
