Heated Glass Element Switch: Service and Repair
The heated back window switch and light is located in the instrument panel finish panel.
2. Remove the console panel.
3. Remove the two instrument panel finish panel screws.
4. Move the instrument panel finish panel forward to gain access to the heated back window switch and light.
5. Disconnect the heated back window switch and light electrical connector.
6. Squeeze the lock tabs of the heated back window switch and light and remove the heated back window switch and light from the instrument panel finish panel.
7. Turn the heated back window switch miniature bulb counterclockwise 1/4 turn and remove it from the heated back window switch.
