Heated Glass Element Switch: Testing and Inspection
1. Key OFF.
2. Disconnect the heated back window switch connector.
3. Apply 12 volts to the "BK/Y" wire terminal on the heated back window switch.
4. Apply ground to the "BK" wire terminal on the heated back window switch.
5. Depress and release the heated back window switch.
6. The indicator should illuminate and stay on.
7. The indicator should go off under these conditions:
a. If the heated back window switch is depressed and released.
b. If 12 volts is removed, or approximately 15-20 minutes have elapsed.
8. If the heated back window switch does not operate as specified, replace the heated back window switch and light. Otherwise, return to the Pinpoint Test. Pinpoint Tests
