Flow of Diagnosis
1. Verify the customer concern by operating the power window system and/or the heated back window system.
2. Visually inspect the components of the power window system and the heated back window system.
Mechanical
- Window alignment.
- Window mounting (regulator and bracket).
- Window frame interference.
- cracked window.
- Front door power window regulator
Electrical
- Blown fuse(s):
+ 30 A POWER WINDOW.
+ 15 A METER.
+ 40 A DEFOG.
- Damage to wiring harness.
- Damaged switches.
- corroded relay.
- Damaged defroster grid.
3. Check the wiring harness for obvious signs of shorts, opens, bad connections or damage.
