Drip Edge Moulding Adjustment
1. Measure the gap between the front door drip edge moulding and the front door window glass and channel surface along the horizontal area of the top of the front door window glass and channel. The gap must be 3.5-4.0 mm (0.13-0.15 inch).
NOTE: The specifications provided have ranges because individual vehicles may vary based on how the front door fits on the car body. It may be necessary to change the front door window glass and channel adjustments to the high or low end of the specification to correct the concern.
2. Use your hands to adjust the drip edge moulding by applying pressure to bend the moulding to provide the required gap.
NOTE: Bend the moulding evenly to avoid a wavy appearance.
