Front - Height
1. With the front door window glass and channel in the full up position, place a straight edge on the front door window glass and channel.
NOTE: The specifications provided have ranges because individual vehicles may vary based on how the front door fits on the car body. It may be necessary to change the front door window glass and channel adjustments to the high or low end of the specification to correct the concern.
2. Measure the gap between the straight edge and the top of the mirror weatherstrip. The gap must be 1.0-2.0 mm (0.03-0.07 inch).
3. If adjustment is required, remove the front door trim panel.
4. Lower the front door window glass and channel 25.4 mm (1.0 inch). Loosen the front door window glass inner stabilizer bolt.
5. Move the front door window glass inner stabilizer to obtain the required specification.
6. Tighten the front door window glass inner stabilizer bolt to 7-9 Nm (60-87 Lb-In).
7. Raise the front door window glass and channel and recheck.
8. Install the front door trim panel.
