Rear Washer Pump and Reservoir
NOTE: The rear window washer reservoir is located behind the LH luggage compartment side cover.
1. Remove the LH luggage compartment side cover.
2. Unscrew to remove the rear window washer reservoir cap.
3. Loosen the rear window washer reservoir filler tube clamp.
4. Remove the rear window washer reservoir filler tube.
5. Lift the rear window washer reservoir from its bracket.
6. Disconnect the rear window washer pump electrical connector.
7. Disconnect the rear window washer hose from the rear window washer pump.
8. Remove the rear window washer reservoir from the vehicle.
9. Pry off the rear window washer pump from the rear window washer reservoir.
