Rear Wiper Switch
2. Remove the console top panel, if equipped.
3. Unsnap and pull up the forward end of the console finish panel to gain access to the instrument panel finish panel screws.
4. Remove the two instrument panel finish panel screws.
5. Pull the instrument panel finish panel away from the instrument panel to gain access to the rear window washer switch electrical connector.
6. Disconnect the rear window washer switch electrical connector.
7. Squeeze the attaching tabs and remove the rear window washer switch from the front of the instrument panel finish panel.
