Rear Pivot Arm
1. Lift the rear window wiper pivot arm nut cover.
2. Remove the rear window wiper pivot arm nut.
3. Remove the rear window wiper pivot arm and rear window wiper blade assembly from the vehicle.
Check and, if necessary, adjust the park position. Adjustments
Tighten the rear window wiper pivot arm nut to 6-9 Nm (53-87 Lb-In).
